Why conntector pin dosen't link to cable
#1 Why conntector pin dosen't link to cable
Hi
I put cable and connector and nothing appears in the table of connector pins.
Can i link cable with connector ?
Thank you
Two things
There are two things you need to rectify in your drawing:
  1. The Cable Connection needs to be used between the blue points of the multicore junctions, as described in the Multicore Cabling tutorial
  2. The connector pins need to be closer together, like so:
Once those items are resolved, you'll need to run Wire Renumbering/Processing.
