Is there a way to quickly update a component to reflect changes made to it in the block editor? I find I can update one component but the changes don't propagate to other components of the same type unless I delete them and re-insert them.
Shopping cart
It depends on the type of element you are modifying.
- If you modify a catalogue part or a simple symbol/block (not one that came out of the block generator), closing and reopening your project will apply the modification everywhere the part/symbol is used.
- If you modify a block through the block generator, than the process will recreate a new block rather than modify the existing one. In this case you have no choice but to reinsert the block.
Good to know! It might be nice to have a button or something that has the same effect as closing and re-opening the project in the future, but that should work well enough for now.
