Hi There
How can I remove the "Insert and Link OPR's" if I need to re-link the again.
For example, I made an OPR for a 24 Vdc and I need to change the source, how can I un-link the current so I can link to the new one.
I tried to delete but did not work ... Please advice
Regards
The only way to unlink am OPR from others to which it might be linked to is to delete it, and re-insert a new one.
Did you make sur to select the actual OPR symbol, or just the cross-reference text? You must select the OPR symbol to delete it.
