Trying to figure out how to replicate this on Skycad Electrical
#1 Trying to figure out how to replicate this on Skycad Electrical
Ok.
Before we can answer you, we need a bit more information about what you are trying to replicate.
- Are the blue square symbols terminals?
- Are the three switch symbols one single 3 pole switch, or three separate ones linked together?
- Are you working in IEC standard or IEEE? (The naming indicates IEEE but the symbol looks like IEC...)
Thanks for getting back to us about that so we can better helo you out with what you wish to achieve.
Ill do my best to answer, but
Ill do my best to answer, but I honeslty I'm not sure about a lot of it since im still learning.
1. I'm not sure. They don't show up on the wiring diagram I used.
2. 3Pole I believe, I'll link the wiring diagram I used intially.
3. I wasn't aware this was a thing. First time touching a CAD software.
Start with those tutorials...
Looking at your drawings, it seems you are using IEEE standard.  To make sure SkyCAD is set-up this way, run quick setup again and make sur to select IEEE symbol standard.  (You will also want to choose 'Rung numbering' on the second question.)
Once this is done, follow the 'Get started' tutorial section in the order the tutorials are suggested, and you should be able to get your drawings done.
Let us know if it works out!
