Transfer swicth
#1 Transfer swicth
how do i repersent a generator transfer switch in skycad
The tutorial should help
In the symbol library, there may be a symbol you'd like to use. If not, it's easy to make your own symbol following this tutorial.
You could also use an existing symbol as a template by selecting the symbol, choosing Open Block from the Home tab, making the changes and applying a Save As. The above tutorial would also help you with that.
