Text size for the terminals
3 posts / 0 new
#1 Text size for the terminals
I would like to change the text size for the terminals from the current 15 to 20 (for example). There were complaints that the text is too small, that the number and name of the terminal could not be seen, etc. How can I do it for all terminals in general?
With best regards,
Branko Nedeljkovic
On your schematics, change the text for one terminal as you wish, then select the terminal symbol, go to the Home tab and Save.
New terminal symbols you add to the schematics, will use that new text size.
If you close and re-open the project, all those terminal symbols will be updated with the new text size.
Thank you, it helps!
