Terminal Strip Management: How to Manually Add an External Connection
#1 Terminal Strip Management: How to Manually Add an External Connection
How do I add custom text to a terminal strip layout?
I want to do This: (done with photoshop for this example)
Well...
There are two way to achieve this:
- Define an 'Incoming' component in the schematic with 'Line 1', 'Line 2' nd 'Line 2' connection ports, and connect to it
- Use the 'Label exterior side' field of the terminal strip view. (This column may be hidden so you'll need to unhide it following the instructions in this tutorial. -- Fast forward to 45sec.)
The second option is probably the easiest to use, but it will put the information using the orange text on top of the terminal instead of adding extra text on the left.
