terminal icons missing
#1 terminal icons missing
Terminal icons are now missing in the menu from ste std envrionment.  where can I find these to copy them back in.
Try this...
The easiest way to get a symbol back in a library folder is to select the terminal symbol from somwhere on the schamatics and click 'Home/Save',.  It will ask you to select a ibrary folder.
when I save it I see that it
when I save it I see that it is already there, but not displaying???
The file already exists, indeed.
SkyCAD will tell you that the file already exists. That's normal.  Keep going forward with the saving process and the file will be overwritten (by itself, no no arm done) and a shortcut will be created in the library folder you selected.
