Hi
When I change the location of the item within the sheet, the tag number does not change automatically. I attached 2 pictures showing details.
Please advice what need to be done. If I delete and re-enter the block again then I need re-modify the in/out terminal locations
Regards
Thanks for your post.
This behaves this way on purpose. Tag numbers being the identifier of elements on the schematic, having them change automatically when the symbo changes position proved to be counter productive. When a component is inserted, a tag value is assigned to it, and it will not change until either you double-click to manually enter a value, or automatic renumbering is processed.
Let us know if that ansered your question.
