Table of Contents Table Size
#1 Table of Contents Table Size  [ Open ]
When inserting a Table of Contents (or any other list table), is there a way to make the overall table smaller? I know you can scale and also make the columns different sizes, but as per the screenshot, the table itself takes up over half the page, so I can't split it on the same page.
Cheers
Split list block, then decrease the column widths?
If you split it using Split list block, then decrease the column widths, you should be able to fit everything on the page.
Please let us know if that helps or if we're misunderstanding something.
I think I found it
So I think I found what was happening. If I decreased the column widths to less than the width of the title, the table would default to a large size, but if I slightly increase the column width to greater than the title, the table would end at the end width of the last column.
Ah, indeed...
Thanks for informing us about that.
