Symbol Library orientation
#1 Symbol Library orientation
Hi Team,
Can you please tell me how to rotate the orientation of the Symbol Library?
Thanks in advance
Do you use IEC or IEEE symbols?
It can be done, but for us to point you in the right direction, we need to ask if you work with IEC symbols or IEEE symbols.
Please let us know and we'll guide you.
Orientation
Hi Team,
Thanks for the quick update. I was just going through some of the other questions and I understand that this is a common issue in Australia. I was working with IEC and now I changed it to IEE. After generating the particular block that I require IEEE, I will probably have to go back to IEC I guess.
Thanks for your support. Cheers
You're welcome
Yes, you can do this. You can even add the IEEE block you created to your IEC symbol libray by right-clicking on the library folder you want to add it to and selecting Add existing graphical block, then searching for your block and clicking OK.
Please let us know if there's anything else we can help with.
