Renaming Terminal Block Layout labels
#1 Renaming Terminal Block Layout labels
Is it possible to rename the labels on the terminal blocks in the schematic to match the labels on the actual pannel that I have built.? Can you please provide steps on how this can be done? I have attached an image of the labels I want to change.
Thank you.
This tutorial should help
This tutorial (from 5:30) shows you how to use the Connect and Disconnect buttons. We're sure this should help.
