Problem with my Stacked terminal view refresh
7 posts / 0 new
#1 Problem with my Stacked terminal view refresh  [ Closed ]
When I make change on with the connection on my Stacked Terminal view, it doesn't refresh the table with the new information.  The only way to see the change is to go back to the single  view and come back after to the stack terminal view.  I didn't had this problem before.  Is it because I download the new version or is because of the revision?
When I make change on with the connection on my Stacked Terminal view (...)
Can you give us a little more information about the changes you are doing?  What do you mean exactly by 'make change on with the connection'?
Thanks in advance!
Connect or disconnect
Why I connect or disconnect.  I am having a lot of problem with the connectivity on my terminal.
Ah! ok...
Thanks for the precisions, we'll look into this and get back to you shortly.
Ok, fixed!
Ok we fixed the issue and uploaded a new version on the server.  If you download version 1.2.128, you'll see it behaves better.
Let us know if it works out!
It work!!
Ok it work now with 1.2.128
Thanks for taking the time to let us know!
