PLC Block Generator - Inserts incorrect Generic Terminal. Adding Channels to the block does the same.
#1 PLC Block Generator - Inserts incorrect Generic Terminal. Adding Channels to the block does the same.
When using the PLC block generator, I am selecting several channels and terminals to add.  Upon Generating a Graphicl Block, the wrong Generic Terminal shows up in the generated block.  As an example, see first clip showing selected items.  In the second clip, you will see that the AI Com becomes a DI Com which i assume is from another line.
How do I change the generic terminal to the correct one?
I did try deleting the terminal and then using the right-click option to add a channel to the block and the same thing happens.  I select the AI Com and it shows up as a DI com from another line.
Comment #5 of this forum thread will explain
Comment #5 of this forum thread will explain why that is happening.
