Unfortunately, you did not zip the right files. We need you to make a ZIP of your SkyCAD Environment. As mentionned in our previous response, this topic will show you how to find out where your environment folder is located.
Thanks for uploading your environment. Now it seems the project you are working on is not stored in the 'Project' folder of the environment. We will need you to attach the file associated to the project 'auto_buffer_3'.
The zipped environment you sent again still does not contain the 'auto_buffer_3' project. We need the project file to be able to open the project and see what's wrong with the panel layout...
We have inserted the image in teh background view of the backplate layout of your project, closed and saved the project, and the image was still there when we openned the project again.
Thank you for posting to the forum.
Here is the link to the Panel layout tutorials.
Please let us know if you need more information.
Have a great day!
Thanks for reply
How can I define the backplane, picture attached ?
thanks
Thanks for your question.
Here's a link to Creating an enclosure tutorial. At 2min4sec we describe how to define a backplate layout.
All the best!
Hi
I did add a picture for the backplane layout but it is disapearing after I start adding the the wire duct .
Please advise
This is strange. Could you make a package of your project and attach it to a reply? We'll take a look at what's going on.
Thanks in advance!
please find attached
regards
Unfortunately, something went wrong while packaging the project, and we can not open it.
The other alternative is to make a ZIP of your environment and upload it here. This topic will show you where you can find the environment folder.
Thanks.
i re-compress teh files again, please check and let me know
Thanks for uploading the project file. We'll look at it in a short while and get back to you!
Can you upload the picture file you used for the backplate background image? Use the 'Image' section of the reply...
Thanks in advance!
What steps are you taking to insert the image?
I did the same as you did , but after I start adding the wire duct the backplate will disappear
