Multiline Text
#1 Multiline Text
When text is inserted an attribute is used. I need to write notes which may be 4 to 5 lines long.
Is multiline line text available?
Yes.
You have two ways to achieve this:
1)  When typing the value, your can press ENTER while maintaining the SHIFT key pressed down.  This will add a carriage return to your text value, making it on several line.
2)  You can select your text, then go to the 'Text style' tab, and click the 'Word wrap' button.
- Once a text is defined as 'word wrapped', you should see a handle appear at the bottom right of the selected text.
- Click and drag the handle to change the word wrap aspect.
Let us know if this answered your question correcty!
