is there a chance to simply modify the numbering rules for the multicore cables? On the picture are two different multicore cables. In real life each cable has its conductors labeled from 1 up. In my drawing cable 2 starts the numbering with number 9 (where the cable 1 stopped its own numbering). I need each multicore cable to start the numbering from 1 so the drawing matches the real life and it is not confusing for my gyus who do the wiring.
Thnak you!
Both cables should have their wire number start at 1, so we don't understand what's going on here.
Could you make a package of your project and attach it to a reply? (Note: ony you and the SkyCAD Staff will have access to your packaged project. All other users won't even be abe to see it.)
We'll look at this as soon as we get you packaged project.
Packaged project attached.
Thanks for uploading the packaged project, but are you certain it's the right one? We can't seem to find the sheet corresponding to the screenshot you posted.
It is sheet #13-Green COM Cable
I made the package again...
Can you see the tree view like that?
Yes, we can, but it looks like our packaging features has an issue with cables. The cable catalogue part seems to be missing from the package.
Let's try with making a ZIP of your environment folder and attach it to a forum reply. This tutorial about backing-up your environment will indicate which folder we need you to ZIP. (Note: As for the packaged file, only you and the SkyCAD staff will have access to your environment file. All other users won't even be able to see the file.)
Environment attached...
Please take note we've contacted you by email about this.
What as the resolution on this? I am having the same problem.
