Multicore cabling - missing the Multi - Cable itself in the Library.
3 posts / 0 new
#1 Multicore cabling - missing the Multi - Cable itself in the Library.
Hi,  Trying to make a multicore cable connection as instructed, I can not find the cable itself in IEC "Multicore Cabling" library. It does have "shield and "Cable" markup, but not a cable.  Consequently, the numbering get mixed and not related.
I tried with a cable from connection, but clearly it is not the right one.
See pics...
Appreciate some clarification  Thanks
Adding something - related
I just deleted by accident the "control"  connection.  Maybe the same happend to the multi cable?  How can I restore the missing deleted item to its library location?
We hope this helps
Yes, it appears so. You can add them back by following these steps.
It is the right one (the cable connection symbol usually appears in both symbol library folders), but it appears that you have inserted the MCJs (multicore junctions) the wrong way around. The blue end needs to connect to the cable connection; i.e. blue with blue.
We hope this helps
