missing wire number / wrong wire number
#1 missing wire number / wrong wire number
I have been modifying my schematic and I don't recall what the sequence of events was, but I added two OPRs (off page reference).
OPR 1: wire on sheet 2 OPR to wire on sheet 7.
a. Original sheet 2 wire is currently numbered as 0207.
b. When I added the OPR to the existing wire in sheet 7, the existing wire number disappeared altogether. How do I get it back?
OPR 2: same wire on sheet 2 OPRed to another wire on sheet 7.
b. When I added the OPR to this wire on sheet 7, the existing wire number on sheet 7 stayed the same. It is incorrectly labeled as 0700. How do I fix this?
Background: both of the wires on sheet 7 were originally wired to terminals and then wired together to a component  pin.
Renumber Wires
If you run Renumber Wires, all should fall into place.
It's probably still there, just not displayed for some reason, possibly related to the OPR being inserted. Renumber Wires should do the trick.
