Linking sequence
#1 Linking sequence
When linking, should the coil be the main component?
First, Power contacts were linked to the coil K12, then NC linked so this component is K12
Second Coil linked to NC, then Power contacts. Component takes K17. I think it should be K15 (Coil)
PhilJ
All symbols are created equal in the eyes of the linking process
Just to be clear, it works as designed. We hear what you're saying about the coil "setting the standard", but it may not always be desired in all cases.
Hope this helps!
