Is it possible to link for example a relay coil to several contacts (multi pole relay)? I seem to only be able to link a coil with one contact. Thoughts? Thanks
If you make a multiple selection or your contact symbols, and click 'Link with' and click on the coil, it should link all contacts to the coil at once.
The solution worked great! Thank you
Thanks for letting is know it worked out!
