Layout Block Assignments
#1 Layout Block Assignments
How would one go about using the same layout block for multiple components. For example, breakers that all have the same external dimensions regardless of part number?
****UPDATE I have discovered the "Assignment from Catalog". That seem to work
You can copy/paste from one component to another
It is possible to simply copy/paste a layout from component to another.
You can do this directly from the catalogue if you wish:
  1. Select a component of a certain class and choose Assign from Catalogue (as you discovered)
  2. Select an item you from the list you know has a layout already defined for it
  3. Go to the Show tab and select Layout
  4. Copy and paste the layout from one component to another
