Latest Revisions in title blocks
#1 Latest Revisions in title blocks
Can I show the latest revisions in my title block rather than just the first ones?
Yes.
Yes this is possible, but a but of a manual work to edit the title block.
- Open your title block in edition mode (select the title block from a sheet, and click 'Home/Open block')
- From the tree view, select the title block item and click 'Show/Graphical sub-objects'.)
- By selecting the text objects one by one, you will eventually select a revision attribute (it will get highlighted on the right)
- Expand it's properties and click in the 'Value' field, even though its greyed out, and deactivate 'Home/Process property queries' (The small button with a '<A>' drawn in it.)  This will allow you to see the queries in properties.
- In the query, you will see a parameter named 'ITEM: ...'.  Change it to 'LASTITEM:...', but leave the item value as it is.)
- Do this for all revision attributes.
- Close and save.
From that point on, revision will show from last and decreasing.
#ERROR# showing in one revision
I've followed the procedure above, and it all works, except for one field.  The latest revision date field shows #ERROR#.  The query in the Value is:
<r:GetRootObject.Getrevisions(lastitem:0).Date>
Other revisions display correctly, and the Value field looks similar, for example:  <r:GetRootObject.Getrevisions(lastitem:1).Date> for the previous revision
That's strange.
Have you tried deleting that text attribute altogether, then copy/pasting the text above it to use as a template?
If that doesn't work, please upload a zip of your Standard Environment folder.
This tutorial about backing up your environment folder will indicate exactly which folder we are talking about.
Note: only you and the SkyCAD staff will have access to your environment. All other users won't even be able to see the file.
FYI, it may take a minute or two for your browser to upload the zip file once you click 'Save'.
Please also let us know which project to look at.
