Labeling color change
#1 Labeling color change
Good morning!
I would like to set all Part Number labels in the project to blue. Is there a way to do this other than exploring each label one-by-one manually?
Austin
Sort of...
There is no way to change them all at once, but you don't have to change them one-by-one either.  If you open a block where that attribute is shown, and change the text properties on the source block, it will be changed everywhere that block is used the next time you open your project.  So you will have to do it for each block used in your project, but only once per block file.
Let us know if this is clear or if you need more information.
I have completed the task in
I have completed the task in the fashion you described. Thanks!
Thanks for taking the time to let us know it worked out.
