Just installed SkyCAD but not opening
6 posts / 0 new
#1 Just installed SkyCAD but not opening
Hi SkyCAD Team.
I'd downloaded and installed with Admin rights.
Created  account. But it is getting closed after loading enviroment screen.
Can you help on that?
Thanks.
Ata
Thanks for posting on the forum and sorry to hear about this! It certainly is strange, but we should be able to get you up and running.
We were able to open SkyCAD using the EnvironmentStructure file you sent, so that doesn't appear to be the problem. Could you try open SkyCAD while holding the CTRL key throughout the entire start-up process?
Also, is this your very first time trying to open SkyCAD or have you managed to open it in the past?
nope...
This is first time trying to open.
holding CTRL opened IE with logon screen. I tried on that with disabling  windows defender smartscreen etc...
nope... it is still same...
Sorry about the hassle!
Our best bet is that something went wrong while installing.  Doing a full uninstall and reinstall should at least let us know if we're right.
If not, we'll dig deeper.
Keep us informed!
Same Problem
I have ecaxtly same problem. I removed and re-install the program, but problem is still exist.
What can I do?
Make sure your Windows language is set to English
Are you in Turkey by any chance? SkyCAD has issues when Windows language is set to Turkish.
The only solution is to set your Windows to English unfortunately.
