[ISSUE] Text info overlap on terminal strip
#1 [ISSUE] Text info overlap on terminal strip
I everyone,
I have an issue with the text orientation of my terminal strip. (wiring connexion info)
I correct it partially by changing the text orientation of the "TS header" of my terminal strip.
I changed it from "Right to left" to "left to right". It correct the case for the 3 layer terminal. But not for the 2 layer terminal.
Here is a picture of my terminals strips:
Thanks for your help,
Math
Left to right is the default. Did you perhaps change it to right to left for some reason? This would explain why the issue is occurring in the first place.
Have you made any special modifications to the TS Header or terminal list items files that you want to keep?
If not, the easiest solution would be to close SkyCAD, delete the TS Header file and terminal list item files from the directory, and install the latest version of SkyCAD on top of your existing version. The only thing the installation would do, is add the default TS Header file. Then, the terminal strip layouts should be behaving as they do by default.
By default, the TS Header file can be found in your directory here:
"C:\SkyCAD Environments\Standard Environment\Catalogue\root class\SkyCad specific Classes\Graphical Element\graphical object\graphical block\work block\list header\TS Header\TS Header V2.SkyCadFile"
By default, the terminal list item files can be found in your directory here:
"C:\SkyCAD Environments\Standard Environment\Catalogue\root class\SkyCad specific Classes\Graphical Element\graphical object\graphical block\List item\Terminal list item"
Please let us know if this helps, or if you have made modifications to the terminal strip layout files (TS Header and terminal list items) that you do want to keep, in which case, we will give you different instructions.
