Internally connect terminals on a block
#1 Internally connect terminals on a block
On blocks, such as PLC, or I/O, or any other block I create with block generator, I want to create connection points that are internally connected, so that a connection line to one results in the same net as a connection line to the other.  Is there a way to do this?
Yes indeed!
Yes, indeed! It's a relatively new improvement so it isn't in any tutorials yet. You do it from within the block generator. Hold down the SHIFT key when adding a connection point.
