It inserts everything verticle instead of horizontally, If I rotate the I/O card then the lines are installed verticlely.
Shopping cart
It looks like you've switched to IEC, perhaps by opening an IEC project.
To switch your project back to IEEE, follow these steps:
You should now be using the Symbol Library (which is the IEEE symbol library) where the blocks are vertical, to accept horizontal conections.
