Hi, there:
I am fairly new to SkyCAD. Is it possible to generate individule BOM for each sheet?
We built customized cabinets so each time there will be slightly difference. To better manage the BOM, I created sub-assembly and create a seperate sheet for each sub-assembly. But when I add the Parts List/BOM, I noticed the parts list table has everything on it. Even after split BOM, the splited BOM doesn't reflect the actual parts on each sheet. Is there a way to do that?
Also, does SkyCAD automaticlly calculated quantity for the same part number. I added two exact same part (resistors) but the part list table show them on two rows with qty 1. Can SkyCAD show the same part in one row and with total quantity?
thanks in advance,
Ke
For parts-list, it is possible but for BOMs it's a bit more complicated. The version you are using does not have that possibility, but we just improved BOM queries in the latest beta-version and we think it might be possible to define a query that would work on a single sheet.
Please allow us a bit of time to check it out and we'll get back to you.
BOMs will do this (increment quantities for a given part-number) but not parts-list, since they list indiviual items.
As mentioned, we'll investigate and get back to you shortly.
Thanks for your patience.
