I need help on How to create Interconnect drawings automatic.
#1 I need help on How to create Interconnect drawings automatic.
How to create Interconnect drawing Automaically?
Use pin-out tables.
SkyCAD uses pin-out tables to allow users to make interconnect drawings.  You insert a pin-out table to each component you wish to see on your interconnect drawing.
- Select your project in the tree view
- Click ‘Show/Components’
- Select any component and click ‘Show/Wiring Pin-out table’
- Once the pin-out table is shown, click ‘Home/Insert list block’, and choose a sheet where you wish to insert the block.
Once the block is inserted, the information will update automatically when the schematics change.
Let us know if that can work-out for you.
