Select the PLC which has the PLC modules you want to show an IO list for
Go to the Show tab and select IOs
This list can be inserted onto a sheet via Insert List Block
It's not precisely what you asked for, as it will also show any IO that are directly on the PLC; i.e. not only the PLC modules. Also, it will show all the IOs associated to that PLC (including modules), irrespectively of what sheet they appear on.
You could go a step further and show only the IOs for a specific PLC module. To do so, directly after step 3 above, you would select the PLC module you want to show an IO list for, then continue with step 4.
Try this:
