Easy way to stretch connections?
7 posts / 0 new
#1 Easy way to stretch connections?
Is there an easy way to stretch connections?
I can stretch 1 connection by moving the red dot at the end of the connection.
I can stretch connections when I move a symbol.
But I would like to stretch the end of multiple connections more easy then 1 by 1.
It's the best we have for now
Thanks for posting the forum.
Unfortunately this is the best we have at the moment.
What should the button
What should the button stretch connections do?
It's what gives you these
It's what gives you these lines when moving a symbol that has connections on it.
Ok thanks.
Ok thanks.
It would help a lot if multiple lines are selected and you move over the end of a line, that the red dot appears so you can move. It can be rather difficult and time consuming to select each connection seperate.
Agreed...
Yes indeed it would be nice. However, we have to set this aside for now as it is much more complex to introduce than expected. We'll get to it eventually, but we can't promise a date anytime soon.
Thanks for your patience.
Ok thanks.
Ok thanks.
