Is there any good way to represent something like this in skycad right now?
https://www.phoenixcontact.com/en-in/products/distributor-terminal-block...
Right now the best and easiest way to represent such a component (where all connection port are interconnected together) is by making one single large block where all connection are grouped through a 'Flow through' connection point group. You would then use OPRs to spread a signal.
We understand it's not ideal, and are currently adding a feature in SkyCAD that would allow to represent one connection point at a time (so in a similar way a terminal from a terminal strip is represented, where all terminal symbols are spread around the project.) We believe that will be the best way to handle you distribution block.
This will be in a new beta-version shortly. We'll let you know once it is available.
