Connected Wire Numbering Format
#1 Connected Wire Numbering Format
On this example, I used standard Control Connection for L1, assigned a different wire numbering to L1, Renumber Wire but the wire is still with number per "Control Connection"
I am trying to udersatand how this 'Conneected Wire Numbering Format' on the Module Teminal works.
Does the format assigned to the Terminal should take presedence over the Connection Wire Format?
PhilJ
Hope this helps
On this example, I used standard Control Connection for L1, assigned a different wire numbering to L1, Renumber Wire but the wire is still with number per "Control Connection".
This is not actually true, though indeed it does seems like it. The Text numbering format is actually very similar to the numbering format that the Control net class uses. Try set the Connected wire numbering format to Empty numbering format, then run Renumber wires and you'll see a difference.
Yes.
