Component to symbol linking
#1 Component to symbol linking
I'm trying to make a symbol that matches a component. However, I can't figure out how to make the component terminals match the symbol terminals.
I have this for the symbol:
And this for the component:
But when I draw the symbol and associate the component it does this:
What should I be doing different?
Thanks for posting on the
It looks like you're trying to use the block generator to create the component, but not using the block generator to create the symbol. This is why it is not working as you wish.
Since you've created the symbol already, all you need to do is use the symbol to create the component.
This tutorial will show you how to do that (except that you won't be using a pushbutton symbol, but your custom symbol instead).
