How can I make my block smaller and line up with the terminals thanks
You can open your block in edition mode and resize the header rectangle to fit the size you want.
- Select your block either from the library or from a sheet where it's inserted.
- Click 'Home/open block'
- Resize the header (the contour line should follow automatically)
- Close and save.
(Note: if you want your generated blocks to come out with that width all the time, check-out this tutorial abotu cutomising the block generator.)
- Close and save.
