When drawing a rectangle I've tried to use the 'chamfer rectangle corners' button in the drawing tab. When I click it nothing happens, the 'Idle function:' indicator says that the chamfer corners command is running but nothing changes with the rectangle.
Shopping cart
You need to scroll with the mouse wheel to set the chamfer radius.
Let us know if it works out for you!
That works! wasn't super obvious to me though, maybe a popup or something that says to use the mousewheel would be useful.
Also this is a bit pedantic but technically a chamfer is a straight cut-off corner and a fillet is a rounded corner.
Good point! We'll see what we can do for a futur release.
Duly noted. We're a bit stuck with the existing documentation though...
