Hi, I would like the wires between IO Cards and to the deive to be different. I can't change one without the other to change as well. Can it be done ? How can I do that ?
If it may help, I added a Screen shot of the terminal (wire base numbered ...) . From the terminal to the PLC, i'd like to have it to be TWE, 18awg, black ... while the other wire is Belden Type, 18 AWG and White ...
Situation can be seen on pages 3.1, 3.2, 4.1, 4.2 and 5.1 ...
If you turn off the Flow Through property of the terminal (right-click on the terminal and choose Explore), then run Wire Renumbering/Processing, you will be able to do it.
