Block generator dimension
#1 Block generator dimension
I create a block and I put a connection port at the bottom of the block instead of being at the right or the left.  I want to put these connection port on the egde of the block but when I try it increase the dimension of the block.  How can I put them on the edge?
Explore block, then set the Contour offset property to 0.
Right-click on the block and choose Explore block, then set the Contour offset property to 0.
