Hey there guys,
I think it would be great if we could right click a certain property anywhere in the UI, and have a "Copy query to clipboard" command. I understand it may need a context to work, and that would be fine to work into the command.
Otherwise, I would like a query to accessories and their part numbers to add to text fields on my layout for this part. I may have multiple text fields with individual accessory part numbers, or one text field with a list of all accessory part numbers.
Austin
I understand it may need a context to work...
That's part of the trouble that makes this unintuitive. Also, sometimes queries simply do not exist in some cases.
We have a feature for that:
This is perfect. Thank you!
Thanks for helping me with the show component property feature. I believe I may have found a bug or am using it wrong.
I go to:
- Select Show Component Property for my disconnect
- Click Show Accessories
- Expand the first one and click the part number field
- Go find the text field dropped by the insertion point.
It contains the top-level component's part number instead of the accessory.
Yip, it's a bug. Thanks for reporting it here!
If you need a workaround, please let us know.
I will take you up on the workaround please. I am struggling in the case of getting a single accessory part number when I have multiple accessories on the part.
Austin
Sorry for the late reply.
Try this:
<r:GetParent.GetParent.GetWorkObjects(Class:Accessory;Item:0).PartNumber>
That query will give you the part number of the first accessory listed for the component.
Item:1 will give you the second, Item:2 will give you the third, and so on.
This works great, thank you.
Hi there,
It seems I am having trouble following these same steps when trying to add an accessory part number query to a custom symbol instead of a layout file. Is it possible to reference the accessory part number on a symbol?
The data sructure for a symbol in relation to the component it represents is slightly different that for a layout, thus the query is a bit different.
Try this:
<r:GetParent.GetWorkObject.GetWorkObjects(Class:Accessory;Item:0).PartNumber>
(Notice the first 'GetWorkObject' does not have a 's' at the end, but the second one does.)
