Adding Function to I-O Class
3 posts / 0 new
#1 Adding Function to I-O Class  [ Closed ]
Is there any immediate reason that I shouldn't add the function Property to I-O Class?
I should just have to copy the Property and the Composition Rule, right?
Well...
Normally you would simply need to copy the property definition, but it seems there is an issue with assigning functions to IOs.
We'll need to create a ticket and fi it before yuo can take advantage of this.
(As mentioned before, the 'Functions' feature is not fully operational, so there are some bumps in the road...)
Ok, thank you.
Ok, thank you.
