4 tier terminal layout
7 posts / 0 new
#1 4 tier terminal layout
Up to 3 tier the terminal layout is ok.
For the 4 tier terminal the layout is missing. How to fix this?
Not true
I made a comment, but there is a representation available for the fuse terminal
Indeed...
Indeed there is no reprensetation for 4 tier terminals in the terminal strip layout.  That's an easy fix as we just need to make a symbol and send if to you.
We'll do this later today and get back to you once it's ready.
That would be great!
Here you go!
We attached a zip file to this reply.  It contains two SkyCAD files:
TS Header V2.SkyCadFile
To replace the one you already have under '<your environment path>\Standard Environment\Catalogue\root class\SkyCad specific Classes\Graphical Element\graphical object\graphical block\work block\list header\TS Header\'
FourLevelTerminalItemV2.SkyCadFile
To add to the folder  '<your environment path>\Standard Environment\Catalogue\root class\SkyCad specific Classes\Graphical Element\graphical object\graphical block\List item\Terminal list item\'
Restart SkyCAD and you should be fine.
It's a beauty
Thanks, it's great
Thanks for taking the time to let us know!
