11 x 17 sheet
9 posts / 0 new
#1 11 x 17 sheet
is there a 11 x 17 sheet?
ANSI B portait?
In other words, a portait version of the ANSI B sheet size we have? Not at the moment. Please let us know if we've understood you correctly and we'll see what we can do.
I would recommend that there
I would recommend that there should be (at a minimum):
ANSI A Landscape
ANSI A Portrait
ANSI B Landscape
ANSI B Portrait
These are the most common sizes used here in the states.
Thanks.
Thanks for your input. These will most likely be added to the next version update.
Update - Create your own sheet sizes
Just so you know, here's an update on this topic. We plan to make it possible for users to create their own sheet sizes soon.
Thanks for your feedback!
11 x 17 portrait sheet
Does Skycad have a 11 x 17 portrait sheet?
Here's how to create your own custom sheets
With the current version (V1.2.112) it is possible to easily create your own sheet sizes. Here's how:
  1. Select a project in the tree view
  2. Go to the Create/Add tab and select New Sheet
  3. In the pop-up window, go to the Create/Add tab and select Create New Sheet Size
  4. Enter the details and click OK
You have now added your sheet to the list and can use it at any time.
Tabloid sheet size with row and column
When I set the project default sheet size to tabloid with row and columns and add pages thay all are with row and columns, but when start SkyCAD again the sheet are tabloid with ladder rows.
Why this happens and how to solve it?
Tnx!
Please follow these
Please follow these instructions to resolve that.
